Aktuelle Zeit: 3. Feb 2026 23:14
Ein neues Thema erstellen Auf das Thema antworten  [ 27 Beiträge ]  Gehe zu Seite Vorherige  1, 2, 3  Nächste
 Betreff des Beitrags: Re: hello, I'm new ASPES member
BeitragVerfasst: 4. Dez 2012 14:03
Hm good question?!
In my opinion the fork from Davids Aspes is like this Model Aspes 1979
Only the first 1979 Navaho had this Fork, the later modells have had the same then on your picture
But if I have a look to the mounted exhaust on Davids bike, it could be the model 79/80. This model has the exhaust from beginnen left motor side to the right side. But I couldn't the the frame of David's bike in details to find the right answer.
Ciao
BeitragVerfasst: 4. Dez 2012 14:23
Davids frame has this bent tube where the shock absorber is mounted, like the later models with plastic tank.
The 79 model that you mean, as I know it, has the straight frame tubes (like Roberts projekt). So the pic of the model that Robert posted above is the right in my opinion, but with the seat of the early 79 model.
BeitragVerfasst: 4. Dez 2012 15:30
Yes of course, your right!
But then the fork ist wrong, it has to be this one here
Gabel BJ80.jpg [37.18 KiB]
Noch nie heruntergeladen
But it is not a problem, it works and it is the less often build fork too.
Ciao
BeitragVerfasst: 4. Dez 2012 20:27
Hello All,
Thanks for your help,
I think the parts on my ASPES are original but perhaps different between France and Germany,
The picture model of RONCO his same mine (exept the tank paint and exhaust end)
on the exhaust end it write "ASPES"
a picture of the good side:
DSC08566 light.jpg [ 80.71 KiB | 12625-mal betrachtet ]
BeitragVerfasst: 5. Dez 2012 07:37
Hi David,
show even more pics of details like the fork and engine.
BeitragVerfasst: 6. Dez 2012 00:10
Hello RONCO,
No problem, I can make some pictures this week-end,
what do you need on the fork and Engine?
If someone need other pictures, please ask
Regards
David
BeitragVerfasst: 6. Dez 2012 12:02
Hi David,
just take a few more pics and post them. So this thread will be more interesting and informative. Often there will be discovered something unusual. So the members are able to give you some hints and advice.
Look at the restoring reports on this forum. They will give you an example how we present the projects.
BeitragVerfasst: 20. Dez 2012 08:56
Hi David,
can you post a pic from your front hub? From both sides. We need to compare to Werna68's hub. He isn't sure if his Aspes has the right hub fitting to the fork.
Greetings
BeitragVerfasst: 25. Dez 2012 12:55
Hello,
Here 2 pictures, I hope it can help you
David
DSC08599 light.jpg [ 112.77 KiB | 12558-mal betrachtet ]
DSC08610 light.jpg [ 99.05 KiB | 12558-mal betrachtet ]
BeitragVerfasst: 11. Jan 2013 23:12
Hat David denn aufgegeben ?
http://www.leboncoin.fr/equipement_moto ... htm?ca=8_s
